converting dwg to PCX during plot missed some lines in the same layeyr.
No aplicable
To feed another software I need to convert dwg to pcx. During plot after conversion some lines of a drawing missed which conversion to pdf kepp all parts. So it seems it is just cause of converting to pcx. And in preview all part are there in place.
Is there any solution out there ?
0 Me gusta
Responder
Soluciones aceptadas (1)
1.596 Vistas
21 Respuestas
Respuestas (21)
No aplicable
First capture is pcx output and second is dwg.
0 Me gusta
imadHabash
can we know your plotter name and how you create it ? also we need your CAD dwg file please ?
Imad Habash
0 Me gusta
No aplicable
From the menu select Tools -> Wizards -> Add Plotter…
Select My Computer and Next
Select Raster File Formats and Zsoft PC Paintbrush PCX… continue with Next.
Continue with Next.
Select Plot To File, continue with Next
Define a name for the plotter AutroMaster.pc3 and continue with Next.Select “Finish”
When the drawing is ready to be converted select from the menu. Files -> Plot
To change the size of the plotted drawing select Properties
Verify that 256 (8 bits color) are defined under Vector Graphics.
Resolutions earlier defined are shown under Custom Paper Sizes. Select on of these or use Add to define a new resolution. I set it W:1680 H:1050
0 Me gusta
imadHabash
check my below attachments ( 60-SG21-00-J01q-0002-Layout1.pcx ) file and see if it's ok ?
waiting your feedback !!
Imad Habash
0 Me gusta
No aplicable
It seems perfect. the capture was just to show what is the issue. I normally should make a window over yellow rectangle (attached) and paper size 1680x1050. May I know how did you fix it? There are several pages I should go through.
0 Me gusta
imadHabash
I've just create the plotter and prepare my settings for plotting . see below image
Imad Habash
0 Me gusta
No aplicable
higher rsolution, less lines miss. Please do the plot to pcx over the whole yellow rectangle in paper size like W:1680 H:1050.
I attached the plotter file.
What would be the problem then?
0 Me gusta
No aplicable
Here is mine and the pcx attached.
0 Me gusta
imadHabash
see attached !!
Imad Habash
0 Me gusta
No aplicable
it is the same as mine, some part of green drawings (J-Equipment layer) still missed.
0 Me gusta
imadHabash
see this one below please .
Imad Habash
0 Me gusta
No aplicable
file is damaged and not opened.
0 Me gusta
imadHabash
Ok!! i get more better result when i plot your dwg to a pdf file and it was perfect . then i use online convertor ( pdf to pcx )  >> Click <<, try it and see if it's good enough . :cara_con_una_leve_sonrisa:
Imad Habash
0 Me gusta
No aplicable
the software that I should use pcx for has problem with online conversion, I tried it before :cara_con_una_leve_sonrisa:
0 Me gusta
imadHabash
in general ... AutoCAD is not the proper software for create images !! you have to expect pixilation and more !!
Imad Habash
0 Me gusta
pendean
Community Legend
Community Legend
Read this, you have to do more than just accept the stock offerings https://thesourcecad.com/how-to-get-high-resolution-images-from-autocad/
0 Me gusta
No aplicable
I accept to loose the resolution quality but at my case it is selective and nothing happened on umbers and just on one specific layer (J-Equipment) some lines are removed. I admit that resolution can be degraded but being removed is odd.
0 Me gusta
No aplicable
I exploded all those green blocks and match the lines with a rectangle I drew. and now all lines are shown in PCX. Seems the block setting has problem which I can not find. and just exploding the block didn't solve the issue until I match the properties with the one I drew. Any suggestion to fix the block? then all drawings using the same blocks will be fixed.
0 Me gusta
imadHabash
draw a new one and convert it to a block with same name to redefine it OR use Express Tools BLOCKREPLACE . >> Click <<
Imad Habash
0 Me gusta
