- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have several AutoCAD generated drawings that are modeled in model space but title block is in paper space. I need to convert these to Microstation (DGN) files. When I follow instructions I've gathered from google, it appears to work except when it comes to the dimensions and the scaling. The dimensions get all out of whack and they cannot be edited and the scaling appears to be incorrect.
I tried opening the drawing in AutoCAD and changing the paperspace to modelspace, but with the viewports, it is only moving one viewport and I can't select additional viewports. I am unable to select all viewports at once also.
Any help with converting dwg files that include a paperspace title block with dimensioning and text, please advise.
Thank you,
BJ
