Reference manager - batch rename xrefs
leticia.campanelli
leticia.campanelli
Hi all,
I am wondering if there is a faster way to do this tedious, time-consuming job.
At my workplace, when changing work (RIBA) stages, the protocol is to copy the files to a new folder and rename them accordingly. This is fine; this can easily be done in Explorer.
When moving and replacing files, all xref files lose their paths; I use Reference Manager to quickly change the paths - also great.
The 'problem' is that I have all xrefs pointing to the correct folder, but they are not showing because the file has been renamed (we only replaced 2 letters).
I am wondering if there is a way to batch rename the internal xref name. I was hoping it would be possible in the reference manager, but I can't figure out how.
As far as I know, it wasn't possible in the previous versions; I am now on AutoCAD 2027.
I hope there is an easier way of doing this that does not involve going into each (hundreds) file and renaming in the xref manager.
If anyone has a good Lisp for it, I would appreciate it if you would be willing to share.
thanks
imadHabash
leticia.campanelli
Thanks ImadHabash,
I am already using the reference manager to change paths.
I came across this Lisp before; it is not really what I am looking for.
With it, I would still have to go into all the files and rename each xref...I might as well do it manually.
I would like something as batch file rename, as they are all referring to the same place. Similar to reference manager with paths.
Thanks anyways
paullimapa
perhaps post your request on the AutoLISP Customization forum to see if you'll get more feedback
Paul Li
IT Specialist
@The Office
