Converting dwg file to STP/STEP format
mmuhammadYKERR
mmuhammadYKERR
So after reseraching for 2 days and reading a bunch of forums, correct me if i am wrong, there is no way to convert dwg files to STP format if i am using standard AUTOCAD3d?
Since most of clients in Fluid Power Industry use STP format this is big hassel. What is my solution ?
pendean
Community Legend
Community Legend
Alfred.NESWADBA
>> standard AUTOCAD3d?
There does not exist a product named "AutoCAD3D" ... for Vanilla AutoCAD (AutoCAD without vertical functions) you are correct, you can export to IGES, but not to STEP.
Maybe it's already a help if you export IGES instead? Most products which can import STEP can use IGES too!
You'll need AutoCAD Mechanical to export to STEP (in case you have the AutoCAD license with Toolsets you can download and install this product and use command _STEPOUT).
Do you have access to AutoCAD Mechanical?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
mmuhammadYKERR
Thank you for correcting my terminology. I have licensed AUTOCAD and i am just downloading AUTOCAD Mechanical. I will let you know if that helps me out.
mmuhammadYKERR
Thank you !! I didn't know i had access to AUTOCAD mechanical. Let me download and i will respond you back.
