Converting drawing from mm to m
Message 1 of 9
When I converted a drawing from mm to m using the scale command, the dimensions do not convert. See the image below. How can I also convert the dimensions to m .
Replies (8)
Message 2 of 9
ennujozlagam
check this article and see if helps. thanks
Message 3 of 9
ВeekeeCZ
Or use the -dwgunits command.
Message 4 of 9
It doesn't work
Message 5 of 9
and the dwgunits command does not work also, see the image below
Message 6 of 9
Johanna_Esteban
Hi @Anonymous,
Once your model is scaled, go to a Dimension Style Manager (DIM command), select the style you want to adjust and modify the scale in FIT.
If you change the value from 1 to 10, it will get 10 times larger (general scaling) or vice versa, which saves you from having to edit the value of each part individually.
Johanna Esteban
Autodesk Expert Elite | Autodesk Certified Professional | AutoCAD Customer Council (Beta Tester for Windows & Mac)
¿Te ha parecido útil este post? ¡Dame Kudos! 😉
Si ha sido resuelta tu inquietud, selecciona 'Marcar como solución' para que otros usuarios la encuentren fácilmente.
Message 7 of 9
pendean
Community Legend
Community Legend
Nothing automatically fixes your DIMSTYLE settings: you need to "fix" them yourself manually using DIMSTYLE command.
HTH
Message 8 of 9
Thank you 🙂
Message 9 of 9
Thank you, for taking the time and helping me solve my issue.
