Converting a .plt to PDF file
Message 1 of 9
I've been given the task of converting some .plt files to PDFs and I cant quite figure it out. They are shown as AutoCAD LT Plot files (.plt). I was told by my boss not to download any programs in fear of getting a virus. I've tried some web converters but none have quite worked. We do have a KIP printer in the office which I've read is a help. I can load the .plt file into the KIP Print Pro app and can see the file in the preview section but I cant seem to be able to convert it to anything. Does anyone know how I might be able to accomplish this conversion? Thanks for the help.
Greg
Replies (8)
Message 2 of 9
imadHabash
i'm afraid that you need a program that can read your PLT files  and a program that can print to PDF.
Good Luck..
Imad Habash
Message 3 of 9
Patchy
Use Kip Request,convert them. We done them all the time.
Message 4 of 9
john.vellek
HI @Anonymous,
If the PLT format is the same format as the same as the KIP then you should be able to follow @Patchy's advice. IF it is a different language then there might be some other options. Is it possible to attach one to a post so I can take a look?
John Vellek
Message 5 of 9
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Message 6 of 9
David125
How do you get Kip Request?
Message 7 of 9
john.vellek
Hi @David125,
Try Kip.com to see if it is available there.  I am not certain there current version is still called that however.
John Vellek
Message 8 of 9
Bsanders_MPS
Observer
Observer
The web converter at https://www.coolutils.com/online/PLT-to-PDF
worked for me...
Message 9 of 9
JMG2A
This worked for me after various other online converter services did not work. Thank you so much.
