converting 2019 dwg files to 2017
Message 1 of 18
Greeting everyone
I have autocad 2017 but i need to edit 2019 dwg files.
the problem is i can't install dwg trueview 2019 to convert it
so maybe someone can convert my attached files
thanks in advance
Replies (17)
Message 2 of 18
Alfred.NESWADBA
without warranty ...
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 18
thank's i appreciate it
Message 4 of 18
Hi, could you convert one of my files too? please!!!!
Message 5 of 18
Alfred.NESWADBA
If you need more files ... you can do that for yourself if you install Autodesk DWG TrueView >>>click<<<
- alfred -
Alfred NESWADBA
Message 6 of 18
Below attached autocad file more recent version. so i need to convert to Autocad 2017 version
Message 7 of 18
Message 8 of 18
cadffm
Sebastian
Message 9 of 18
ennujozlagam
please...@Alfred.NESWADBA  the most you can only convert to autocad 2013 see attached. thanks
Message 10 of 18
Alfred.NESWADBA
@ennujozlagam
I would have waited for a "please" 😉
@Anonymous
We in the forum, the guys that try to help others for free, are not your private support guys. A bit friendliness is always an advantage when needing something done by others to help you.
- alfred -
Alfred NESWADBA
Message 11 of 18
ennujozlagam
@Alfred.NESWADBA sorry my apology....please. thanks 😉
Message 12 of 18
Alfred.NESWADBA
Hi @ennujozlagam
I hope you understood it the right way ... I would have waited for a please from "nizamsafras12", not from you!!!
My apologizes if I this was understood the other way!
- alfred -
Alfred NESWADBA
Message 13 of 18
I want to convert this file to 2017 version
Message 14 of 18
Alfred.NESWADBA
Open the file and run command _SAVEAS and set the filetype to "DWG-2013" or use command -EXPORTTOAUTOCAD.
- alfred -
Alfred NESWADBA
Message 15 of 18
@Alfred.NESWADBA ,
Could you please help me convert DWG 2019 to 2017? appreciate
Message 16 of 18
@Alfred.NESWADBA
also for these 2 files. Please
Message 17 of 18
cadffm
@Alfred.NESWADBA would you do my work too?
It is not so much, ~8h a day, 5 days a  week, just 46 weeks per year.
Thanks in advance
Sebastian
Message 18 of 18
Alfred.NESWADBA
All your files were already saved in DWG-2013 format, so you can open them with AutoCAD 2017 without any conversion.
- alfred -
Alfred NESWADBA
