convert x_t to dwg
convert x_t to dwg
Message 1 of 9
convert x_t to dwg
Maxim,
If you're out there, John Vellek--he's out of the office for a couple of weeks--suggested I contact you.  I am running AutoCAD 2018 on a MacBook Pro (mid 2015) running OS 10.13.6.  I've been given a ParaSolid x_t file, and I need it converted to a dwg file so I can work with it.  Is this something you can help me with?  I've attached the file--it's not terribly big--2.4 MB.
I've tried posting twice, and it doesn't seem to be working--maybe 2.4MB is too big, if so, an error message to that effect would be nice.
In any case,  I've zipped the file--it's now 716KB.
Thank you,
P James Norris
Replies (8)
Message 2 of 9
Alfred.NESWADBA
I'm not @john.vellek, however I converted the file and attached it here.
Please verify the units and the geometry itself as I can't give any warranty).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 9
Mr Neswadba,
Thank you very much for the very quick reply and converted file--I really appreciate it!
I'm able to open the file, bu when I do, I'm given the attached warning, and I'm not sure what it means.  Are the 409 unsupported objects not being displayed?
Thanks!
P James Norris
Message 4 of 9
Alfred.NESWADBA
interesting, is this file attached now showing the same messages?
- alfred -
Alfred NESWADBA
Message 5 of 9
Mr Neswadba,
No, the file now opens without the warning about unsupported objects--can you tell me what you did differently in this conversion?  Are the previously unsupported objects going to be visible/editable?
Thank you,
P James Norris
Message 6 of 9
Alfred.NESWADBA
Great, so you can continue to work 😉
The first file was created with AutoCAD 2019
The new file was created from the previous file + run command -EXPORTTOAUTOCAD and saved it back to DWG-2013 format.
That are no geometry objects (in case of that file), it's just some additional settings within the file (maybe from ObjectEnablers I have installed) you won't use/need to use.
So at least: what you see as imported geometry is the same 😉
- alfred -
Alfred NESWADBA
Message 7 of 9
john.vellek
Hi @Alfred.NESWADBA,
Thanks for helping the OP. I am out of the office for a little bit and I am so glad that I can rely on your excellent contributions to the Community.
John Vellek
Message 8 of 9
Alfred.NESWADBA
Alfred NESWADBA
Message 9 of 9
Hi
I saw that you managed to convert an x_t file to DWG.
I wonder if you could do the same for me or tell me how to do it myself.
Kind regards
Nisim
