Convert to Device Scaling Problems
So, i am trying to create a new type of electrical device in AutoCAD after creating a block. So ive created the block, then i convert it to a device, but when  i attach this new device to my tool palette and insert it into other drawings, and then try and change the scale, the device stays the same size. How do i make it to where the newly created device changes with the scale of the drawings that i insert them into?
imadHabash
>> ....and insert it into other drawings, and then try and change the scale, the device stays the same size. <<
would you tell us how did you get that and by what command ?
>>How do i make it to where the newly created device changes with the scale of the drawings that i insert them into? <<
This is what Annotative blocks can do . >> Click <<
Imad Habash
BrianBenton
What do you mean by "device"?
Blocks can be "associative", that means they will scale up/down with the scale of your viewport. If you make your block associative it will scale automatically when you change the scale of your viewport.
Brian C. Benton
bbenton@cad-a-blog.com
http://CAD-a-Blog.com
twitter.com/bcbenton
www.facebook.com/CADaBlog
