Hide material behind block when printing
When inserting multiple blocks how can I make it so that lines behind a a block (directly behind) do not print. without using hatches.
imadHabash
>> how can I make it so that lines behind a a block (directly behind) do not print.  <<
WIPEOUT command will serve your issue . edit your block if with wipe option that will always hide any thing behind your block . >> Click <<  just draw a polyline around the circumference of your block or around the area the you want to hide elements behind , then by wipeout command complete the mission .
Imad Habash
