convert segmented aligned lines to a single line
Is there a lisp that would recognize a set of aligned connected lines and would change it into a single stright line?
Something like connecting lines into polyline, using PolyLineDiet to get rid of unnecessary nodes and exploding polyline would do.. just I don't need PL so it is work around and I didn't figure how to convert multiple sets of lines into polylines at once.. PE does only one connected set at one run and I have a plenty of those..
Trying to clean up an export of elevation view  from sKetchup.. It breaks lines in every intersection even only apparent intersection..
AutoCad Map 3D 2016
ВeekeeCZ
The JOIN command will convert many segmented lines to one line.
ВeekeeCZ
Just for the record... if you draw a line, break it into pieces and then re-join them using JOIN command, you'll get a single line. That's happening in 2020.
