Convert PDF to DWG File
How can I convert a PDF file to DWG file?
pendean
Community Legend
Community Legend
The PDF you shared with us over here is Raster based: to convert it to DXF/DWG file format you will need to purchase a 3rd party converter to use outside of AutoCAD. Explore here https://www.google.com/search?q=raster+to+vector+software
J'ai une solution à votre problème. C'est une question très courante que tout le monde se pose. Je connais un outil gratuit en ligne dans lequel vous pouvez fusionner pdf, ajouter plusieurs images et les convertir sous n'importe quelle forme. Il est très facile de convertir un pdf dans cet outil, essayez-le une fois. Merci... 🙂
jrreid
Looks like your PDF file came from Small or Single Public Restrooms | ADA Guidelines - Harbor City Supply
Contact them and see if they'd send you the CAD file...
But if you Google that name above on your drawing and say CAD FILE you will get all those details you can use to make this drawing with very little time involved.
Hope this helps.
JRR.
jrreid
Here is a link to some of the best details for ADA.
If you scroll down to the bottom that is where the public restrooms are.
You should be able to use these to make what you are needing.
Online ADA Design Guide - Bradley Corp
Hope this helps.
JRR.
