I need to convert a curved surface to a region so I can fuse it to another region. How can I accomplish this?
Region to surface not an option, I cannot go vice versa.
@wispoxy, john.vellek has edited your subject line for clarity: Region To Surface - Vice Versa Not An Option
Solved by wispoxy. Go to Solution.
Wow, I typed out my title wrong and now I can't change it. I need a curved surface to a region as said on my main post.
The title may work.... It's not very specific... hmmm....
The border of a Region can be curved, but Regions only exist as a flat surface.
Hi Andrew,
I don't have a quick answer for you but if you could attach a sample file I am happy to take a look and research internally to see if I can come up with something for you.
Hi @Anonymous,
That's the direction I was leaning too but wanted to test on OP's drawing. Thanks - can you provide a good example for other users?
Hi @wispoxy,
I am curious if this got resolved. Selecting the surface and giving it a thickness will change it to a 3D solid. I assume your region was created using section?
Can use section on the new solid to create another region? you could then connect the two?
Apologies, went on vacation for 10 days the Wednesday after posting.
@Anonymous and @john.vellek, I can't release the cad, it's a consumer product to be released under contract. I'll try converting everything to a solid, then convert all the solids to a region with this > INFO <. It's very important the lab gets the cad as a region. Results will be shared today by 2:30 EDT.
P.S. @john.vellek Thanks for changing the subject line.
Ok, it's good. I turned the Curved Surfaces to Solids, then Solids to a Region. Crossing my fingers for Autodesk to cut this process from three major steps to a max of two. This was a first for me and I don't think I'll be doing it for awhile again. Played with some parts for a while, but got everything exactly the way I wanted it. Thank you all for the help, and have a great new year!
Glad it worked out. Usually, for most of us, the solid is our desired end product. I've never had need to produce a region except as a method to create a solid.
However, to the best of my knowledge you cannot create a curved region, you can only create curved surfaces. Even copying a face from a cylinder will result in a surface, not a region.
IF you don't need to original solids and only want the regions/surfaces, EXPLODE the solids. There's no need to use the SOLIDEDIT>FACE>COPY method.
I had to use SURFTRIM, convert to solid, then EXPLODE (as you mentioned) before converting to region. The faces I don't care about, it's the points of the 3D wiremesh I needed. That perpendicular solid connection worked beautifully. Got my drawing approved by the lab
