Been looking for this for a while, I'm starting to think it's more of a Windows thing rather than an AutoCAD System Variable or such.
As the imagem attached shows, when I hover the mouse over my AutoCAD instance in the Windows 10 taskbar, I get as many thumbnails as I have files opened in that same instance.
However, in a coworker's computer it shows only one thumbnail, regardless of the ammount of drawings opened (it shows only the most recently edited).
Is there a way to change this, either through AutoCAD or Windows configurations?
Solved by pendean. Go to Solution.
I know this is an old thread but the system variable you are looking for is TASKBAR. Set it to 0 and it will only display the current drawing. Set it to 1 and it displays all the open drawing. It also affects the behavior of using Win-TAB to switch applications.
Putting this here in case someone in the future is looking for this and finds this thread.
