AutoCAD Forum
Contour scale different (X, Y, Z)
3 REPLIES 3
villelamatheeus97
329 Views, 3 Replies
Hello, everyone!
I made a mapping flight using a drone and generated some information, such as contour lines.
Opening the contour file in GIS software, the scale between the X, Y and Z axes is correct. However, opening the DWG file in the CAD software, the scale on the X, Y and Z axes changes.
The Z plane remains with a vertical equidistance of 1 meter, but the X and Y axes appear with strange millimeter scales, as if in the process the meters were transformed into millimeters. The contours assume an absurd distance on the Z axis, as if they were much further away from each other. 
How to fix this problem? Are there any settings that can be made so that the X, Y and Z axes are scaled correctly?
Thank you, everyone.
Labels (5)
3 REPLIES 3
pendean
in reply to: villelamatheeus97
What's the GIS software exactly?
What variant of AutoCAD are you using?
Hi @villelamatheeus97,
Welcome to the Autodesk Forums.
Hard to tell from your screen shot. Can you zip together and post your drawing and data? And as @pendean requested it would be good to know what other software you're using and what version of AutoCAD.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
villelamatheeus97
in reply to: pendean
ArcGIS and QGIS. Working well.
Actually using AutoCAD 2018.
Technology Administrators
