06-24-2022
01:03 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-24-2022
01:03 PM
Contour scale different (X, Y, Z)
Hello, everyone!
I made a mapping flight using a drone and generated some information, such as contour lines.
Opening the contour file in GIS software, the scale between the X, Y and Z axes is correct. However, opening the DWG file in the CAD software, the scale on the X, Y and Z axes changes.
The Z plane remains with a vertical equidistance of 1 meter, but the X and Y axes appear with strange millimeter scales, as if in the process the meters were transformed into millimeters. The contours assume an absurd distance on the Z axis, as if they were much further away from each other.
How to fix this problem? Are there any settings that can be made so that the X, Y and Z axes are scaled correctly?
Thank you, everyone.
Etiquetas (5)
Etiquetas:
- Etiquetas relacionadas:
3 axis
3D contour
Contours
scale dwg
units of measure
