AutoCAD Forum
continues dimensions hide
6 REPLIES 6
618 Views, 6 Replies
Dear All,
Please Help me i'm frustrated,
i'm using cad from last 10 years but no any same issue before.
i'm currently working on auto cad 2014
from last 2 weeks i'm working on one drawing but suddenly hide their only continues dimension another linear,angular all dimensions remains still.
so please help to recover all dimensions.
Dear All,
6 REPLIES 6
ennujozlagam
ennujozlagam
i don't understand what do you mean? can you explain more. thanks
imadHabash
imadHabash
>> ...but suddenly hide their only continues dimension another linear,angular all dimensions remains still.<<
please guide us more where should those continues dim appears and how did they hide ? your dwg has errors which can be fixed by Purge ( Reg ) and recover . see attached dwg file ( small file size ) and see if your problem solved .
Imad Habash
Imad Habash
in reply to: ennujozlagam
PLEASE CHECK DRAWING
IM GIVING FIRST DIMENSIONS BY USING DLA COMMAND OR DLI (LINEAR DIMENSION)
THEN USING DCO (CONTINUES DIMENSION) AND PUT MORE DIMENSIONS.BUT AFTER 2
DAYS ONLY CONTINUES DIMENSIONS ARE HIDES.THEN AGAIN GIVING DIMENSIONS.
AFTER THAT THEIR ALSO HIDES.
SO PLEASE HELP FOR UN HIDE THIS DIMENSIONS.
THIS ISSUE IS 1ST TIME IN MY 9 YEAR CARRIER.
ennujozlagam
ennujozlagam
@Anonymous hello, i cannot find anything wrong it works for me. no off layer. try to install lates tupdates from autodesk and see if helps. thanks
Or try to show us in screencast video on what are you trying to achieve.
CAN I RECOVER HIDE CONTINIOUS DIMENSIONS
imadHabash
imadHabash
>> CAN I RECOVER HIDE CONTINIOUS DIMENSIONS <<
RECOVER command repairs and then opens a damaged drawing file . i suggest to look in your TEMP folder ( C:\Users\your user name\AppData\Local\Temp ) for an old Bak file which you can rename the extention to .dwg and see if your dimensions still there.
Imad Habash
Imad Habash
AutoCAD Inside the Factory
