Content exists but not visible
Message 1 of 29
I worked on this drawing a month ago and need to make some edits now, but both the model space and paper space are blank (in the screenshot a border in paper space is seen but when I REGEN it disappears). When I plot, everything that I had drawn prints perfectly (put doesnt show in the preview).
I've tried all the normal things like making sure layer visibility is on, REGENALL, Zoom extents, and whatnot. Suggestions?
Replies (28)
Message 21 of 29
cadffm
your post doesn't help anyone. If you have a similar problem, but you can't solve it - Feel free to share your data and we can show the issue & solution, if possible.
Sebastian
Message 22 of 29
kondri2LJYK
Observer
Observer
I just installed AutoCad LT 2025. Drawing is there but not visible neither in Model space nor in paper space. I created a new drawing, it is the same thing.
Message 23 of 29
dbroad
Looks fine to me.  Strange colors though.
Architect, Registered NC, VA, SC, & GA.
Message 24 of 29
kondri2LJYK
Observer
Observer
I just installed AutoCad LT 2025. The content is there but not visible. I created a new drawing, it is the same thing.
Message 25 of 29
cadffm
I am using the autocad mobile app and I can see everything(?) In layout, also the model objects.
Sebastian
Message 26 of 29
cadffm
and in LT2025, also
Share your Screenshot!
open the file,
go to Model
Command ZOOM extents
screenshot
and the same for both layouts..
Sebastian
Message 27 of 29
cadffm
Set GFXDX to 0
Type in and set it to 0
Problem solved?
Turn hardwareacceleration off
GRAPHICCONFIG
Problem solved?
Update your LT2025 with the last update
Sebastian
Message 28 of 29
Alfred.NESWADBA
May I ask how you verified that the content exists while you don't see it?
This answer could help us to identify your issue.
For me: I agree with @cadffm, I can see a lot of data in modelspace and layouts.
Tip: run command _AUDIT as there exist 20 errors with XData, however this has nothing to do with a display problem.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 29 of 29
Ashwin.PatelFCNJJ
Community Visitor
Community Visitor
I have AMD Radeon HD6770 and following Steps Solved it for me.
In Autocad Application
Type in a Command: OPTIONS
Click on the Graphics Performance Button
If Hardware Acceleration is ON,
(A) you may want to Turn it off OR
(B) if 2D Display Settings is "Advanced Mode"  Change it to either "Intermediate Mode" or "Basic Mode".
Then Click the OK Button on the Dialog Box.
