AutoCAD Forum
Drawings units changing on its own
4 REPLIES 4
mwright1971
1437 Views, 4 Replies
I have a drawing from a client. When I first open the drawing, the units are set to inches (which is what I want it to be). But as I work on it, at some point the drawing automatically changes to millimeters. Has anyone run into this problem or have an idea or solution? It's really annoying, especially when I have to keep scaling blocks down that should be the correct size. Smiley Frustrated
4 REPLIES 4
imadHabash
in reply to: mwright1971
HI,
>>  But as I work on it, at some point the drawing automatically changes to millimeters. <<
i thinks that it's changed because of installing or apploading lisp routine or plugins .
Imad Habash
Erense
Check both MEASUREMENT and MEASUREINIT variable in the drawing.
MEASUREMENT set to 0 = Imperial (Drawing setting)
MEASUREINIT set to 0 = Imperial (System setting) (applied when opening file)
Both should have the same setting.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
mwright1971
in reply to: Erense
I tried the changing the variables, but it eventually went back to millimeters. Oh well, no big deal. It's a drawing from one of the clients we work with and they know just enough about AutoCAD to be dangerous and they are! Thanks for responses everyone!
Siovan
Hi
I had the same problem exactly with an external file from a client. I just used a trick to bypass the issue:
- command DWGUNITS
- set the drawing unit to what you desire (in this case: inches)
- ok
- when the pop-up asks about scaling, just select "Don't rescale any existing objects"
- save a copy of the file
from now on, it will not switch units automatically.
Hope it works for you too.
Thums up
AutoCAD Inside the Factory
