Constraints Missing from ribbon!
Message 1 of 13
My ribbon is missing the constraint tools under the parametric panel. Capture.PNG
I am using the drafting and annotation workspace and have all panels checked ON. All Constraint bar display settings are checked as well. I have also tried to "repair" AutoCAD with no luck. Please help.
Replies (12)
Message 2 of 13
ara_neresesian
Hi
try load menu .
type "menu" and select acad.cuix and open it .
good luck
Message 3 of 13
This is already loaded on mine by default.
Message 4 of 13
ara_neresesian
load  something else and then reload acad.cuix
Message 5 of 13
Nothing happened. Still unable to see tools in ribbon.
Message 6 of 13
ara_neresesian
How about menu ?
do you have it at menu parametric pull down?
Message 7 of 13
I'm not sure I understand this question completely. Can you rephrase?
Message 8 of 13
justin_mortensen
A work around is to use the GC command, it pulls up all of those constraints in the context command menu.
Message 9 of 13
ara_neresesian
Message 10 of 13
vinodkl
You are using AutoCAD LT 2020 and LT does not offer the facility to add contraints. You can edit/view them if the contraints are added from AutoCAD full version.
Limited Parametric Drawing Functionality in AutoCAD LT
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 11 of 13
cadffm
LT STUDENT ? Why?
Why you using this limited version, unusual (for me).
Here we are in the AUTOCAD Forum, AutoCAD LT is over there -> Click!
Sebastian
Message 12 of 13
Maypareja
Community Visitor
Community Visitor
I am using AutoCAD LT 2025 and I have the same issue where I cannot see constraints from ribbon. Any help would be greatly appreciated.
Message 13 of 13
pendean
Community Legend
Community Legend
@Maypareja wrote:
I am using AutoCAD LT 2025 ...
LT versions of AutoCAD have exceptionally limited CONTRAINTS abilities, mostly all you can do is remove them. If you need more than that, you need to subscribe to the more expensive full AutoCAD instead of LT.
Can't see that RIBBON tab? It might be turned off since it has limited abilities in LT versions of AutoCAD, but you can turn it on with a right-click in the Ribbon area
