Constant Text Height in Paper space regardless of scale
george.bodnar
Observer Observer
Message 1 of 22
george.bodnar
Observer
Observer
My company does not use consistent scales and I am asked to change the zoom level often.  I would like text in paper space to be a constant height regardless of zoom level.  Is it possible to make the text height always 2 (or any other height) regardless of scale?  Therefore, if they ask me to change the zoom for a plot, I do not have to change the text height each time.
Replies (21)
Message 2 of 22
ara_neresesian
HI
Select parametric Object and change the "CONSTRAINT FORM" to  Annotaional .
SEE PIC.
good luck
Message 3 of 22
Kent1Cooper
This is exactly what annotative text styles are for.  Learn about them in Help, or search for videos, etc.   But be aware that you may need to reposition such things at different scales to avoid clashes.
Kent Cooper, AIA
Message 4 of 22
Alfred.NESWADBA
Just to add one idea ... are you using plain AutoCAD (Vanilla) or do you have access to Map 3D or Civil 3D?
In both applications there exist other methods to have the option to not depend on annotative scale, but have the option to get symbols and text scaled in reference to the paper and not to the model.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 5 of 22
george.bodnar
Observer
Observer
I am using (vanilla) AutoCAD
Message 6 of 22
Alfred.NESWADBA
Then sorry, you'll need to use the annotative settings to get that done.
- alfred -
Alfred NESWADBA
Message 7 of 22
RobDraw
This is the problem. Someone needs to determine the desired scale before the bulk of the work is done. The people asking you to change scale need to realize that that seemingly simple request requires additional work on your part, especially if the scale gets smaller and text/symbols start to overlap.
Annotative scaling is great for consistent sizing for paper space but it is not the solution for changing scales on the fly. I'd be pretty frustrated if I were asked to change scale on a consistent basis and would do whatever I could to prevent this from happening.
Rob
Message 8 of 22
murray-clack
I wrote a short tutorial for my office on how to use Annotation Scaling.  Feel free to use and share
The OTHER trick is to physically put your annotation objects in paperspace so that if the Viewport scale needs to change, the text stays put in both position and height.  You will have to redirect some leaders and whatnot
UPDATE - if DIMASSOC is set to a value of 2, the leader arrowheads will automatically redirect themselves if they are object snapped to the item you are labelling.
Message 9 of 22
dbroad
As @RobDraw  explained, AutoCAD's annotative scaling system isn't designed to support arbitrary scaling or zoom on the fly.
Although autoscaling text is possible, such capabilities would require customization and would require that the zooming happen in a paper space viewport and that the text be in model space. If it's worth it, then get your company to invest in adding that feature by hiring a consultant.  Otherwise, annotative text styles along with sticking with a limited number of pre-defined scales would be your best choice. Annotative text objects are worth using and are already built-in.
Architect, Registered NC, VA, SC, & GA.
Message 10 of 22
s.borello
You need to use annotative text... this way the text will appear the same size in a viewport regardless of scale.  Youtube has videos showing how to do this.
Message 11 of 22
a.zwegers
Simplest solution: put paper-objects like texts and (annotative, associative) dimensions in paper space.
Model space is the 1on1 representation of the real world... you don't see large pieces of text floating by outside your window either, do you? 😉
Message 12 of 22
ara_neresesian
HI
if any one knows about reactors  maybe  can help you to create a text with dynamic height regardless of scale,
just watch how  Parametric dimensions works, by zooming  in and out the height of  text is fixed  .
you can put this condition for reactor
if  (custom scale)  changed  in paper space  then change  text height in mode space
i am trying to create that text
good luck
Message 13 of 22
Alfred.NESWADBA
Not that easy, think about having 2 viewports side-by-side, one viewport is 1:1 and the other is 1:2
You can't modify a text height in modelspace so both viewports show the same text object in the same size measured in paper units.
You need to have overrides of objects for the display so you can catch the DRAW function for each of the viewports separately, you can't do that with changing the text object itself.
- alfred -
Alfred NESWADBA
Message 14 of 22
george.bodnar
Observer
Observer
Thanks.  But if the scale changes then the text placement in paper space will not match the scale changes in model.  The text size will be correct but the text will be in the "wrong place."
Message 15 of 22
george.bodnar
Observer
Observer
Thanks to everyone who took the time to reply.  As I suspected, it is not possible to do to have a constant text size after zooming in or out.  Annotative text only accomplishes this with set scales and therefore will not work.
Message 16 of 22
dbroad
I understand the need to mark a solution, but this issue hasn't solved as much as "accepted".  We need a new button that will never be added to the forums, with an X symbol rather than a checkmark and text such as "Uncle", "Can't be solved", "I give up", "Let' move on", or "Software limitation".
Message 17 of 22
TiStars
Agree with you, so I marked it back to "unsolved"
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
您的问题是否已得到解答?请点击“接受解答”按钮。
Message 18 of 22
m.roseP2SQE
Community Visitor
Community Visitor
This is by far one of the best and most thorough documents I've seen that explains annotative objects, scaling and their relationships to model space and layout space yet.  Excellent article.
Message 19 of 22
murray-clack
Glad you liked it!  I have several other tutorials that I've written for my office to use.
My Sheet Set Manager tutorial is especially good 😉
Message 20 of 22
TiStars
Sheet Set is really good tool to manage drawings!
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
