I've received a file from a surveyor, and it contains complex linetypes. If I choose to "reverse" the polyline, the text does not flip. What is the parameter within the linetype description that will allow me to reverse a polyline and have the text flip? thanks
Try the following example. I created two linetypes for overhead electric lines, one rotated 180 degrees so the text is always readable. The setting "A=180" is the only difference.
*OE,Overhead Electric ----OE----OE----OE----OE----OE----OE--
A,.5,-.2,["OE",STYLUS,S=.1,U=0.0,X=-0.1,Y=-.05],-.2
*OE_180,Overhead Electric-Rotated180 ----OE----OE----OE----OE----OE----OE--
A,.5,-.2,["OE",STYLUS,S=.1,U=0.0,A=180,X=-0.1,Y=-.05],-.2
Or from AutoCAD's own Help:
Check the linetype definition if you have access to it, for the rotation part of the text-inclusion entry:
Create those linetypes and play around with the A and R settings. Draw some lines in all different directions and you'll see what the settings do.
Is it even permissible to have two rotation entries? If it doesn't give you any invalid error, I assume the second one rules, and the first one is ignored and therefore removable.
I'm no linetype expert. I'm sure I created these through trial and error. I do get a different result if I take out the "U=0.0"
I did some testing... To get the result I wanted, both rotation factors have to be in there.
