AutoCAD Forum
complex linetype issue
11 REPLIES 11
Message 1 of 12
MKH-VB
689 Views, 11 Replies
I've received a file from a surveyor, and it contains complex linetypes.  If I choose to "reverse" the polyline, the text does not flip.  What is the parameter within the linetype description that will allow me to reverse a polyline and have the text flip?  thanks
mkh
11 REPLIES 11
Message 2 of 12
imadHabash
in reply to: MKH-VB
Your linetype (.LIN ltype definition) used for the respective line or polyline may use the "upright" alignment code (always readable). I suggest to follow this link that may help . >> Click <<
Imad Habash
Message 3 of 12
MKH-VB
in reply to: imadHabash
Wout the u option work if I have the drawing with the linetype xreffed into another dwg, with a dview twist?
mkh
Message 4 of 12
cjneper
in reply to: MKH-VB
Try the following example. I created two linetypes for overhead electric lines, one rotated 180 degrees so the text is always readable.  The setting "A=180" is the only difference.
*OE,Overhead Electric ----OE----OE----OE----OE----OE----OE--
A,.5,-.2,["OE",STYLUS,S=.1,U=0.0,X=-0.1,Y=-.05],-.2
*OE_180,Overhead Electric-Rotated180 ----OE----OE----OE----OE----OE----OE--
A,.5,-.2,["OE",STYLUS,S=.1,U=0.0,A=180,X=-0.1,Y=-.05],-.2
Message 5 of 12
Kent1Cooper
in reply to: MKH-VB
Or from AutoCAD's own Help:
Check the linetype definition if you have access to it, for the rotation part of the text-inclusion entry:
Kent Cooper, AIA
Message 6 of 12
MKH-VB
in reply to: cjneper
Not sure what the "a" variable represents
mkh
Message 7 of 12
Kent1Cooper
in reply to: MKH-VB
See the right side of the first image in my previous Reply.  Or better yet, go to Help and look around.
Kent Cooper, AIA
Message 8 of 12
cjneper
in reply to: MKH-VB
Create those linetypes and play around with the A and R settings.  Draw some lines in all different directions and you'll see what the settings do.
Message 9 of 12
Kent1Cooper
Is it even permissible to have two rotation entries?  If it doesn't give you any invalid error, I assume the second one rules, and the first one is ignored and therefore removable.
Kent Cooper, AIA
Message 10 of 12
cjneper
in reply to: Kent1Cooper
I'm no linetype expert.  I'm sure I created these through trial and error.  I do get a different result if I take out the "U=0.0"
Message 11 of 12
Kent1Cooper
@cjneper wrote:
....  I do get a different result if I take out the "U=0.0"
That would imply that if there are two rotation entries, the first one wins.
Kent Cooper, AIA
Message 12 of 12
cjneper
I did some testing... To get the result I wanted, both rotation factors have to be in there.
AutoCAD Inside the Factory
