I Want to ask you what function has got the command MBUTTONPAN? ,in addition the command NAVBARDISPAYwhen has got the price=0 and when has got the price=1?
and what function has got the command navswheelmode=1,navswheelmode=2,navswheelmode=3
thank you
Solved by Emmsleys. Go to Solution.
@Anonymous wrote:I Want to ask you what function has got the command MBUTTONPAN? ,in addition the command NAVBARDISPAYwhen has got the price=0 and when has got the price=1?
thank you
The help file defines those for you. Press F1 and search away.
HI @Anonymous,
Take a look at the following links where you can find the description of each system variable mentioned and the commands associated with those commands.
Please select Accept as Solution if my post or any other post in this thread resolves your issue, or reply with additional information if the problem persists.
