AutoCAD Forum
command MBUTTONPAN
2 REPLIES 2
1352 Views, 2 Replies
command MBUTTONPAN
I Want to ask you what function has got the command MBUTTONPAN? ,in addition the command NAVBARDISPAYwhen has got the price=0 and when has got the price=1?
and what function has got the command navswheelmode=1,navswheelmode=2,navswheelmode=3
thank you
command MBUTTONPAN
thank you
2 REPLIES 2
thank you
The help file defines those for you.  Press F1 and search away.
thank you
Emmsleys
Emmsleys
HI @Anonymous,
Take a look at the following links where you can find the description of each system variable mentioned and the commands associated with those commands.
MBUTTONPAN
NAVBARDISPLAY
NAVSWHEELMODE
Please select Accept as Solution if my post or any other post in this thread resolves your issue, or reply with additional information if the problem persists.
Sarah Emmsley
Technical Support Specialist
HI @Anonymous,
MBUTTONPAN
NAVBARDISPLAY
NAVSWHEELMODE
Sarah Emmsley
AutoCAD Inside the Factory
