AutoCAD Forum
command locking up.
3 REPLIES 3
239 Views, 3 Replies
command locking up.
On executing commands. such as  Line, copy, dimension, circle, etc whatever........at times the execution freezes for 5 to 10 sec. and then continues....
          However it is just so time consuming to wait to proceed with work.  What is wrong, is  it the computer or the program, or a setting that I am not aware of.
Thank you.
Alex B.
3 REPLIES 3
pendean
What changed recently for you on your computer? Something did, find out.
Also list what your AutoCAD version is, Windows version, and if this problem is in ALL files or just some files.
in reply to: pendean
Good Morning Dean Saadallah,
I do not believe anything has changed on my PC,  my Cad version is 2011, PC windows is Vista Ultimate.
This locking up is occurring on all DWG. that I work on.
Thank you
Alex B.
pendean
Vista has WIndows System Restore: start it and it will tell you what changed in your PC from the day this started happening.
You can also explore these links for settings in AutoCAD that may help:
http://www.cad-notes.com/disable-graphic-hardware-acceleration/
http://www.cad-notes.com/speed-up-autocad-configuration/
Forma Design Contest
AutoCAD Beta
