Command line text alignment
Message 1 of 21
Hello i'm having a problem with the alignment of the command line text, i don't know why the text is aligned to the right... does anybody know how to align the text to the left?
Thanks!
Replies (20)
Message 2 of 21
stevetamplen
Hello alejo_vega, and welcome to the Forums!
I am having a hard time reading the little screenshot you posted.
Can you please attach the screenshot to the post so we can get a better look?
Also, what version of AutoCAD is this?
Steve Tamplen
Technical Support Specialist
Message 3 of 21
the version is 2017, i don't know how to attach the screenshot...
Message 4 of 21
TheCADnoob
have you tried closing the program and opeing it again?
CADnoob
Message 5 of 21
yes.. i tried in the CUI configuration but i didn't find anything for command line configuration...
Message 6 of 21
rkmcswain
If you dock the command line, does it still behave like this?
Message 7 of 21
when the command line is dock the text align at the left... but when is not dock it align right
Message 8 of 21
stevetamplen
I have tried and I cannot duplicate this error on my system in Windows 7 and AutoCAD 2017. It aligns left no matter what I have tried.
Have you tried resetting AutoCAD to defaults?
How to reset AutoCAD to defaults
Can you please try logging into Windows as a different user and see if the program behaves correctly?
If none of those things work, please send the following information:
What OS you are using?
What is the brand and model of your video card, and the driver version?
Steve Tamplen
Message 9 of 21
dbroad
@Anonymous
I believe what you are observing is standard behavior for the floating command line.  At least, I have the same behavior here on AutoCAD MEP 2014 - AutoCAD MEP 2016 in the as AutoCAD profile and the AutoCAD 2016 program.  Perhaps the designers were thinking that it keeps the focus of the design less cluttered with ghost text.  This would seem reasonable, especially if you like to keep the drawn geometry that you are working on close to the left part of the command line.
Does it bother you much?  I generally keep the command line docked because other things seem to work so much better.
Architect, Registered NC, VA, SC, & GA.
Message 10 of 21
stevetamplen
@dbroad
That is very interesting, as two of us here at Autodesk were unable to duplicate the behavior, even when undocked.
@Anonymous
Does this behavior only display in Model Space?
Steve Tamplen
Message 11 of 21
stevetamplen
@Anonymous
Did any of the posts get your problem resolved? If so, please hit the Accept as Solution button on the appropriate post so that more community members can profit from the solution.
Please post back to let us know.
Steve Tamplen
Message 12 of 21
i didn't try reseting autocad to default settings, i will try it, but till now a couldnt find a solution.
Message 13 of 21
stevetamplen
As long as you are willing to work on it, we (the Community) are willing to help!
Steve Tamplen
Message 14 of 21
i reset autocad to default settings, but the same problem with the command line...
Message 15 of 21
stevetamplen
@Anonymous
So you have tried resetting AutoCAD to defaults, and tried logging into a different Windows user profile, correct?
What Operating system are you using?
Can you please post a drawing that shows this behavior?
Can you try changing your workspace to see if that changes the display?
Also, can you please send a screenshot of your CUI command line settings?
Do you have any Large Fonts or Windows Themes installed?
Steve Tamplen
Message 16 of 21
I do not know if it is still actual. Anyway, in order to get rid of that strange alignment, just slightly increase the size of the command line in vertical direction, so it will able to contain at least 2 rows and the problem will gone. I struggled with the same problem. See pics below.
BR
Oleksii
01010202
Message 17 of 21
anyone found a solution (except docking) ? - for me the problem still persist in Autocad 2020
Message 18 of 21
cadffm
1. You mean except docking AND except to entlarge it to more lines visible
2. Docking the commandline protects against some strange peculiarities that are always there when the command line is not docked.
    Not many problems, but really strange things (and YOU will never search for the issue in your commandline(position).
3. I guess it is an windows or graphic thing (both things outside of autocad)
Sebastian
Message 19 of 21
cadffm
Message 20 of 21
thanks! - changed to left-handed in tablet PC settings and now the command line ist on the (right) left side.
