Command Confirmation
hello,
i am having an issue with my autcad.
when a perform a command(move, copy), once completed, it asks" Do you really want to do this" my only option is no and it undoes the command i have performed.  i tried typing in yes but it still undoes what i just did.
can anyone help me, asap.  it allows me to complete commands for some highlighted objects, but not all.
thanks for the help
Patchy
Try OVERKILL, then Audit and PURGE.
Your drawing is filled up and autocad can't process that many entities.
thank you,
i am not familiar with these commands and tried looking them up on youtube but still dont seem to help me. i purged my file and still continues to ask the question. it does it particulary to an exref file that i have, not sure if that helps.
Patchy
Your XREF has a lot of hatches? that would do it.
pendean
Community Legend
Community Legend
john.vellek
HI @Anonymous,
Overkill removes duplicated entities that sit on top of each other. Try running it at the command line by typing overkill and typing all when prompted for object selection.
If you can't get this far, then start AutoCAD and user the Recover command (under drawing utilities) and select your drawing. If this works then open your drawing and purge it out, run overkill and possibly reduce the number of entities in the drawing.
If you would like to attach your drawing to a post I would be happy to look at it as well.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
