Some Commands have stopped working
My matchprop command has stopped working.
When matchprop (MA) is typed in it says command is unkown.
mwn
What version of AutoCAD are you using?  This forum is specific to the Web version of AutoCAD 360 which doesn't have a matchprop command currently.
-mike
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
Autocad 2014
Thank-You
Pino Lavecchia, B.T. Arch.
Architectural Manager
[Dunpar Signature (2)]
105 Six Point Road
Etobicoke, Ontario
M8Z 2X3 Canada
Tel: +1 416.236.9800 x 249
Cell: +1 416.206.9749
Fax: +1 416.236.9080
Email: p.lavecchia@dunpar.ca
Web: www.dunparhomes.com
sthompson1021
You can try using the REDEFINE command. When it prompts for a command name, type in MATCHPROP. If that don't work you can try to reset settings to default.
john.vellek
Hi @Anonymous,
The easiest way to get things back to factory - normal is to run a Reset Settings to Default. Are there are other commands that also aren't working?  Have you recently gone through any upgrades?
Windows updates? What version of Windows are you running?  Does your AutoCAD have service packs installed from here?
John Vellek
After a few commands stopped working and repairs did not seem to work I reloaded Autocad 2014 and now it is working fine.
Good to know about the REDEFINE command for future.
