I have a problem with the below command line when I am running this step in lisp
(command "Join" "All" "")
I am getting error, attached the screenshots.
But it is working in the other trail version.May i know why it's not working in my machine?
Vijay Kumar
Solved by rkmcswain. Go to Solution.
Hi Sir,
Thanks for quick reply.
Did you observe the Error screenshot and working screen shot.
it says function cancel error
But in working screenshot, it was successfully run and there is no error.
Different versions of AutoCAD?
Try this where it currently does not work.
(progn (initcommandversion 2)(command "._Join" "_All" ""))
Documentation on (initcommandversion)
