Civil3D object enabler version(s) for AutoCAD Map 3D versions
prxcad
prxcad
We're using AutoCAD Map 3D 2018 and 2019. We often receive .dwg files that were created in Civil 3D (various versions), and we'd like to install object enablers for M3D to be able to handle the C3D-specific objects.
It is not clear to me what the version of the object enabler (e.g. 'Autodesk Civil 3D 2021 Object Enabler') refers to:
Does it refer to the version of C3D that the data was created with? If so,
  • Could we install that same OE (e.g. 'Autodesk Civil 3D 2021 Object Enabler') on both our M3D 2018 and M3D 2019 machines?
  • Would this OE also be able to handle data that was created with all previous C3D versions, or would every C3D version that we receive data from require a separate OE? If separate OEs are needed, would we be able to install multiple OE versions on the same machine (e.g. C3D 2021 OE + C3D 2020 OE + C3D 2019 OE... on one M3D 2018 machine)?
or does it refer to the version of AutoCAD that this OE is to be used with? If so,
  • Would we need the 'Autodesk Civil 3D 2018 Object Enabler' for our M3D 2018 machines and the 'Autodesk Civil 3D 2019 Object Enabler' for our M3D 2019 machines?
  • Would these OEs be able to handle data that was created with the latest C3D version (e.g. Civil 3D 2021) and all previous C3D versions?
Thank you in advance for any clarification!
vladimir_michl
Even Civil 3D in an older version cannot understand Civil objects from a newer version (with exceptions in some releases) so don't expect the Object enablers to behave this way. Install the same OE version as the hosting Map application.
Vladimir Michl, www.arkance-systems.cz - www.cadforum.cz
rushabhthakkar_910
@prxcad , To get a More better response, Post your Query in AUTOCAD Map 3D Forum and Civil 3D Forum...
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
pendean
Community Legend
Community Legend
you need to be running 2021 or 2022 versions of your software if you want access to content created in C3D2021 or C3D2022. That's how it is designed to work, there is no backdoor option with older year-versions. Sorry. You need to upgrade.
prxcad
Thank you for your replies,
p.
