Changing Text Height of Multiple Texts
emily.j.murphy
emily.j.murphy
Is there an easy way to change the text height of multiple lines of text at the same time?
I have to change the annotative scale and text height of multiple lines. I was able to change the scale by clicking on all of the separate texts and going to the properties. But it won't allow me to change the height from there... I have different text all over my drawing that need to be the same height.
Can I do it all at the same time, or do I have to change them all separately?
pendean
Community Legend
Community Legend
STYLE command controls height if you set it up that way.
BUT...MTEXT is not "text" since MTEXT can have manual overrides inside each occurrence that can be a total standalone.
So are you having trouble with TEXT or MTEXT? Or ATTRIBUTEs? And is what you want to fix in STYLE command?
emily.j.murphy
I think I figured it out! I had forgotten to change my annotative scale to match the rest of my drawing. When I changed it back, the text changed to the correct height...
Thank you though!
