Changing default save name
How can I change the default save name. Currently the default is whatever the projects name is. I want it to default to a number which will be an attribute in a block. Is this possible?
pendean
Community Legend
Community Legend
No such ability built into the program: you will need to customize with a macro or LISP.
Walk us through your commands of choice adn where you want this name to appear and maybe someone around here can get you started with a few lines of code.
Ok. I installed hanna batch plot. This allows me to automatically plot multiple blocks on one model and save them all at once as PDF's in a set location. But when it saves, the name is just "Layout-01" (current file name) etc. For each block we have a system that gives them different REQ numbers. This number is an attribute in the blocks, and I want the hanna batch plot to save them as that attribute number.
dmfrazier
Your question would be better directed at the Hanna Batch Plot developer(s).
Based on a quick scan of the app, it looks like your wish would require a modification.
pendean
Community Legend
Community Legend
We don't address 3rd party software: you need to get that help from their support forums or their product support teams.
