Is there a way to change the default minimum/maximum arc lengths for a revcloud in AutoCAD 2023? I found the REVCLOUDMAXARCLENGTH command but it's obsolete.
Solved by Valentin-WSP. Go to Solution.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
@adetweilerCNW6N wrote:I found the REVCLOUDMAXARCLENGTH command but it's obsolete.
What else did you try
So this changes the dimensions in the specific drawing. Is it possible to change the default min and max arclength of the system? Currently without any modifications the default are
@adetweilerCNW6N wrote:So this changes the dimensions in the specific drawing. Is it possible to change the default min and max arclength of the system? Currently without any modifications the default are
Sorry, not possible.
