Hi all, i've exported a plan from revit (.dwg) and in ACad i can change color only to few lines; more precisely i can't change color to doors, windows and curtain walls, either if i change layer or object's color.
What it could be the cause??
Thank you!
Solved by john.vellek. Go to Solution.
Hi @Anonymous,
I haven't seen this issue before. Is it possible to attach the file so I can take a look?
I've already tried to attach the file but it says: The attachment's unità abitative1.dwg content type (text/plain) does not match its file extension and has been removed.
Hi @Anonymous,
Try putting the file in a ZIP file and then attach. If that doesn't work I can send you a link to an upload location.
Hi @Anonymous,
This is pretty simple I believe. The objects that are not changing color I think are all blocks. You can redefine the blocks using Block Edit or even easier try using the SETBYLAYER command.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
That's embarassing, I haven't even noticed that those were blocks!
Thank you a lot!
