Change command without deselecting objects
santhoulakis
santhoulakis
Sometimes we spend a lot of time selecting a group o objects and then by mistake give the wrong command. As a result, the selection is lost.
How can we keep our selection and just insert another command? Is there a setting that would keep the objects selected unless e.g. Esc is pressed?
Patchy
Use P for Previous selection.
vinodkl
Even after deselecting, you can select back the same objects by using the "previous" option. Here is how you can do that.
Type in the new command after deselection like "MOVE" now press "P" and enter which would select the previous selection. There are many option like "Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/Previous/Undo/AUto/SIngle/SUbobject/Object"
You can just type in the Bold letters highlighted above after the command to create different selections🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
aadish_bin_abdul_sathar
thank u very much 🙂
