Insert line parallel to other that snaps to tangent of arc nearby
LGL_Design
Message 1 of 13
LGL_Design
I hope someone can help me.
But snaps to the tangent an arc nearby.
Dotted line is just positioned by hand, that that is what I essential want.
Thanks in advance
Replies (12)
Message 2 of 13
paullimapa
Have you tried using Copy command Line AB with base point by object snapping to endpoint of Line at B and the 2nd point as  object snap Tangent to Arc then Trim section of Line at A that’s not needed?
Paul Li
IT Specialist
@The Office
Message 3 of 13
imadHabash
The fastest way is to use from Parametric ( GCTANGENT command ) .. Click on below image
Then you can delete the constraint by DelConstraint command from the same previous menu
Imad Habash
Message 4 of 13
leeminardi
Using perpendicular object snap create a line from the center of the arc to line AB. Now copy the line AB from B to the intersection of the perpendicular line and the arc.
lee.minardi
Message 5 of 13
LGL_Design
If I understand you correctly, then it results in this:
Message 6 of 13
LGL_Design
This is 100% what I want to achieve, but I am using AutoCAD LT, it doesn't seem to have full access to parametric constraints as shown in the video / image above.
Message 7 of 13
LGL_Design
This worked, perfect, thank you.
Message 8 of 13
imadHabash
You're right ... 😉
In AutoCAD LT, parametric drawing technology is limited , While it is not possible to create or edit geometric and dimensional constraints in AutoCAD LT, you can still view, work with, and save constrained drawings.
Imad Habash
Message 9 of 13
LGL_Design
Thanks for the info.
I suppose the onus is on us (LT users) to find creative work arounds, and share with the community.
Message 10 of 13
leeminardi
@LGL_Design  You are welcome. It looks like in your first try the the perpedicular line was not from the center.  Here's what I got.
lee.minardi
Message 11 of 13
-didier-
Bonjour @LGL_Design
Your line is secant, not tangent.
Here is my proposition :
Amicalement
(view in My Videos)
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
Message 12 of 13
LGL_Design
In my first attempt I was replying to someone else.
Your method work perfectly, thanks.
Message 13 of 13
LGL_Design
perfect thanks.
