Certain line types not showing in paper space and in model space - PLEASE help!
Hello, I have a project due for school Monday and I cannot get my line types to display properly. I have changed PSLTSCALE, MSLTSCALE, CANNOSCALE, ETC. trying to get it fixed and none have helped.
It is a hospitality project, so my room types are individual blocks that have blocks within them of different line types. If my unblocked model is showing the correct line types in paper space, the blocks don't show the correct line types and vice versa. I have read all the other forums and tried what they suggested, but nothing has worked. I attached my file.
Can someone please help me? I have only used AutoCAD for 3 years, I need guidance!
MakCADD
try with matching the dwgunits and paper size
fatal.error
Type ltype command, uncheck "Use paper space units for scaling", click OK and type rea command to regenerate all.
Original:
Fixed:
Hello! Thanks so much for your response. That made some of the line types show, but not the dishwasher clearance or the upper cabinet dashed lines. Do you have any other solutions?
fatal.error
Just set the Dishawasher Clearance Polyline's Linetype scale to a bigger value, such as 10.
