AutoCAD Forum
Centerline Default Settings
1 REPLY 1
2685 Views, 1 Reply
In the 2019 version of AutoCAD, there is a tool that automatically adds a centerline in between two selected lines. That centerline has modifiable end points that extend past the edges of the object (typical for a centerline). My question is how do I change the default length of those extensions? Can I also change the length of the short line in the middle? Obviously, I can modify it every time I do an individual centerline, but that's going to get tedious. Is there a place I can change this default to fit the ANSI of .25 inches past? If so, where?
Thank you for any feedback.
1 REPLY 1
Alfred.NESWADBA
Alfred.NESWADBA
>>>there<<< you can find all the system variables you can define for center-line.
As these variables are all stored in a dwg-file you can open your template, edit these settings and save back this drawing as your new template.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
- alfred -
Alfred NESWADBA
AutoCAD Inside the Factory
