Cant select objects
Cant select objects
u2144305
Observer Observer
Message 1 of 9
Cant select objects
u2144305
Observer
Observer
For some reason i cant select objects for reason i the layers are not locked. I tried the PICKADD options .
Replies (8)
Message 2 of 9
u2144305
Observer
Observer
Message 3 of 9
paullimapa
would you share your dwg?
Paul Li
IT Specialist
@The Office
Message 4 of 9
Patchy
Thaw and On your layer 0
Defpoints layer works that way.
Message 5 of 9
pendean
Community Legend
Community Legend
Message 6 of 9
TomBeauford
The defpoints layer is only for leader nodes definition points and should never be used for drawing objects.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Message 7 of 9
Kent1Cooper
Follow @TomBeauford's advice in Message 6, and you can Search for more discussion about this.  If you want something to not Plot, make a non-Plotting Layer for it, with a name that means something related to what it's about.
But to elaborate a little bit:  When Layer "0" is either off or frozen [or both], objects on Layer "DEFPOINTS" cannot be selected, nor can you Object-Snap to locations on them.
Kent Cooper, AIA
Message 8 of 9
javier.zavala
Check the object selection settings. Type "options" in the command line and go to the "Selection" tab. Make sure "Noun/verb selection" is enabled and "Pickfirst" is set to 1
Message 9 of 9
cranetechmike
I had a similar problem, and I did <CTRL> A to select all, and manually deselected my visible objects, then deleted the remaining objects.   That fixed my problem.
