- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Im working with some drawings that I didnt create. All I did was copy them off the server to my local machine and bam, all the external references to raster images are broken. No big deal, just a new path right? I right click, choose IMAGE, choose EXTERNAL REFERENCE and I can see the information about the reference. Sure enough, the path is wrong. So I click on that field to adjust the path. Nothing. The field is greyed out. Right click. Nothing. Look for a "BROWSE" button. Nothing.
As far as I can tell the path cannot be changed. The only two work arounds I have found so far is to either just delete the raster image and insert a new one, or save the file as a DXF, go in with text editor and find the path, change it, and then save back as a DWG.
Surely there is GOT to be a better way right? Why cant you just click on the reference and browse to the new path? This seems like a massive oversight, how did they not think that we would want to do that?
Any help on better ways to fix this? Thanks!
