Cannot snap to objects in an anamorphically scaled block
mjohanson
mjohanson
I inserted an anamorphically scaled block (x=1:1, y=50-:1) and need to place dimensions between objects in this block. Some intersections are selectable and others are not. Does anyone have any suggestions on how to fix this?
Patchy
Flatten command
or/and explode after that.
GrantsPirate
Have you tried apparent intersection (app) instead of intersection (int)?
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
imadHabash
i think some of your block components have a Z factor.check it OR you can ignore these Z factors by OSoption(see attached)
Try it and i hope it's work
Imad Habash
mjohanson
Thanks. Flatten worked. I was not aware that some of the objects had some z value.
