Cannot 'explode' or ungroup a group of lines
maddyj
Message 1 of 17
maddyj
please help i have a '16 line' group i want to ungroup, won't accept 'explode or xplode' command and option to 'degroup' is greyed out as it is a 'group. any help apprecaited!
Replies (16)
Message 2 of 17
vinodkl
Looks like you have grouped more than one group together and its become nested group. Try using the command "UNGROUP" and see if it works. If not try posting your file so that we can have a look.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 3 of 17
cadffm
[ESC]
[ESC]
Select ONLY "one" of the lines.
Now you see all 16 selected?
Ungroup works fine, but only for groups. RightClick, Groups-> Ungroup = Greyed out? -> isn't a Group
and Right Click -> Is "Block Editor" available?
Then it is a Blockreference.
Use it, start BlockEditor(command: BEDIT) Inside the BlockEditor, open your PropertiesPalette, scroll down, enable allow exploding
BSAVE
BCLOSE
try it again
Sebastian
Message 4 of 17
ChicagoLooper
Have you checked the LAYER? If it's locked, try unlocking it.
Chicagolooper
Message 5 of 17
imadHabash
you can explode the block while Insert command .
also you can change all block behavior to be explode or not from BLOCK command ( select your block first ) .
Imad Habash
Message 6 of 17
Simple and effective solution - it worked !
Message 7 of 17
KRD023
Community Visitor
Community Visitor
hey could you help me i haveing same issue
Message 8 of 17
CGBenner
@KRD023
Hello and welcome.
Have you tried the marked solution above from @vinodkl?
Chris Benner
Message 9 of 17
Kent1Cooper
The same issue with what?  Have you tried not only the accepted solution [using UNGROUP] but also evaluated for whether what you cannot Explode is a Block?  [Blocks can be defined to not allow Exploding, but you can fix that.]  Most importantly, what happens when you try Exploding or Ungrouping?  Post a small drawing file containing whatever you are having the issue with.
Kent Cooper, AIA
Message 10 of 17
CGBenner
@KRD023 Hello, do you still need help with this question?
Chris Benner
Message 11 of 17
steve_delabastide
Community Visitor
Community Visitor
Layer is unlocked. Ungroup & explode still not working. I can add to the group but not separate it.
Message 12 of 17
cadffm
Just an idea
share your sample drawing
Sebastian
Message 13 of 17
pendean
Community Legend
Community Legend
@steve_delabastide Look up PICKSTYLE variable in your program's HELP and turn if off. Is your group now ungrouped?
Also.. start LIST command (type it), select this GROUP and see what AutoCAD things it is at the commandline (that needs to be 5-10-15 lines tall for this example). PROPERTIES command, if you have that palette open, will also tell you what that ungrouped GROUP is. Share those results here.
Message 14 of 17
cadffm
Hi again, may I wild guess?
  because that is the only logical explanation I see
1. You are really talking about Groups (the topic above was about blocks, just the title and description just used the wrong vocabulary)
2. Your statement "I can add to the group " is not correct, you mean you can create a new group!?
   Thanks to pendeans "Also.. start LIST command ", which led me to a test and indirectly to the following assumptions:
3. You are talking about existing group only? Draw two new circles, group them and ungroups works too?
    What you do is: Object selection, contextmenu (rightclick) -> Group -> [Group] [Ungroup] [Add to Group] [Remove from Group] ?
4. Now, you have an existing group, you click on an object, the group is highlighted and you open the context menu -> Group
    What you see is that just the first menu item available only: GROUP
    (when you said "I can add to the group ", you mean this, what create a new group - not add an object to the existing group)
    All three other context menu items are greyed out. Is this what you see on your side, is this your issue?
If so:
You selected objects who are members of two or more groups!
Greyed out, but the commands behind are still working well.
Try command: UNGROUP
Try command: GROUPEDIT option ADD
Try command: GROUPEDIT option REM
Also available in ribbon, start, Panel group
See also, the free help and product documentation [F1] for more information about Groups, group comm...
Sebastian
Message 15 of 17
steve_delabastide
Community Visitor
Community Visitor
Good morning,
Many thanks for your reply. Kinda weird that some of my grouped units I can ungroup, but then some I cannot. Even the explode won't work.
Steve
Message 16 of 17
cadffm
Hi Steve,
>>"Kinda weird that some of my grouped units I can ungroup, but then some I cannot."
What is with my possible explaination (above)?"
>>"Even the explode won't work."
If you have two circle, what should command Explode do with them?
Please, we like to learn: Share your sample! .dwg (you can delete what you like, except the one example of group)
Sebastian
Message 17 of 17
pendean
Community Legend
Community Legend
@steve_delabastide wrote:
...Kinda weird that some of my grouped units I can ungroup, but then some I cannot....
Show us: share that actual DWG file here with those objects in them. if you cannot, go ask your boss/client for permission or ask them to help with your issue perhaps.
