I am creating a template drawing but while making this drawing I was working on two different versions of AUTOCAD (2012 & 2013). I have prepared my title sheet block but there are two scales in the drawing and I want only one i.e that is 1:1 but somehow there is one more scale which I am sure is coming 2012 version. I am trying to remove this scale as both the scale has same factor but I am unable to delete it as it says its being used by some object. I searched everything but could not find which object is using this 1:1000 scale. Need help to remove this scale and load only standard scale.
Without your file we can not show where your problem is..
- You can not erase anno-scales which
1. are in use
2. was the native anno-scale 1:1
If you like to get help, upload your DWG. (so we can check where the scale is in use)
If you like to try it self, try this:
Set the other one current, are you able to delete the 1:1 now?
If yes, rename 1:1 to test, rename the othe one to 1:1 (and make sure the definition is 1:1),
now you can delete "Test" and you have only one anno-scale - "1:1"
Sebastian
I am attaching file but I am not sure if it is getting attached.
click here to get the file
Two problems
1. You use both scales! (please set each tab (model and layouts) current and check your properties palette (without selected objects)
Can you see the 1:1 AND 1:1000 scale as current setting? And you can not erase scales which are in use..
2. The "1:1000" scale is the real native "1:1" of this file, so you have to delete the 1:1 and rename the 1:1000 to 1:1
I show you a "normal user way":
Use command: FILTER to select all viewports! [Filter: Viewport, Apply to ALL]
Now, you can set viewport scale an aoonotation scale in the properties palette to 1:1000 for all layouts (viewports)
set 1:1000 in modelspace too.
Now you can delete 1:1 and rename 1:1000 to 1:1.
Is it working for you now?
Sebastian
@cadffm wrote:
Two problems
I do not have any viewports yet in my drawing. FILTER command isn't the way as you are saying. There is something that I am not doing correct but i can't figure it out.
>"I do not have any viewports yet in my drawing. "
No user defined viewports, thats right, but you have system-viewports, one for each initialized paperspace 😉
You answer show me: You never tested what i offer you as solution.
If you have a problem and ask for help, follow my words. a) respect and 2. it is the solution for YOUR problem.
>"FILTER command isn't the way as you are saying."
Command: FILTER
add "Viewport" to the Filterlist
apply to ALL
In your file you have 3 layouts and all was minimum 1 time current, so filter will find three (system internal) viewports.
My Sample picture is not from your file, but the steps are the same.
And check your private messages 😉
Picture edited..
Sebastian
