Cannot create dome..
Message 1 of 39
SO I cannot create dome in the center... I creaed spline and two arcs in the middle. When I try to loft these, it wonk work. I also tried using NETWORKSRF, but stilll havent been able to achieve it :(( What am I doing wrong here?
Replies (38)
Message 2 of 39
Alfred.NESWADBA
please find attached a video for how to get that part done.
2 additional suggestions:
  • instead of turning layers off please use "freeze layers" (makes you more safe against modifying objects you did not want to and also make the display faster).
  • never use layer "defpoints" for your objects (this layer has a special meaning for AutoCAD and is used internally.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 39
imadHabash
use REVOLVE command to revolve the arc around the vertical and central line 360 to get what you ask for ( see below image).
Command: REVOLVE
Current wire frame density: ISOLINES=4, Closed profiles creation mode = Solid
Select objects to revolve or [MOde]: 1 found
Specify axis start point or define axis by [Object/X/Y/Z] <Object>:
Select an object:
Specify angle of revolution or [STart angle/Reverse/EXpression] <360>:
Imad Habash
Message 4 of 39
What is UCS? WHy do I need radius line of circle to be closed? When I close it, then i cant join spline with other two lines... when I join them without closing, i cant revolve them...
Message 5 of 39
I need it in solid...
Message 6 of 39
Alfred.NESWADBA
>> What is UCS?
A command to specify a User-Coordinate(you can't work without that whenever you do some 3D work.
And the help of AutoCAD can be asked first!
For a command: type in the command-line of AutoCAD
UCS<ENTER>
and then press <F1> 😉
To get a 3D-solid as result.
Only closed contours will create 3D-Solids when running commands like _EXTRUDE or _REVOLVE
- alfred -
Alfred NESWADBA
Message 7 of 39
I did that as You showed me in video finally :0 how can I confirm that dome is solid? Because i cant Union both parts...
Message 8 of 39
Alfred.NESWADBA
Either run command _LIST and select your object, or open the property window and look to the top line while your object is selected.
Look to the command-line when you start the command _UNION, it tells you:
At least 2 solids, surfaces, or coplanar regions must be selected.
So as the dome is a 3D-Solid the other object is it not, and I guess the second object you selected was the array, am I correct?
An array is not a 3D-Solid (even if it consists of 3D-Solid objects).
What you can do is to start command _EXPLODE, select the array ==> so the parts of the array are selectable now ... then you can run command _UNION with the other elements + the dome.
[EDIT] if you want to run _UNION with the parts of the array, you'll need first to make 3D-Solids from that parts, that are only surfaces.
Sorry, have not seen that before [/EDIT]
- alfred -
Alfred NESWADBA
Message 9 of 39
When I do Explode, yes the petals are selectable. But then when I _Union, petals and frame with dome become two bodies
When I try again _union on them,  It says that one of these arent solid
Message 10 of 39
beyoungjr
Post 3 showed you the revolve method but the contour shown in @imadHabash's example is not a closed boundary.  Thus the result is not a solid but a surface.  To get a solid you would need to follow the advice in post 6 by @Alfred.NESWADBA where he explained to use a closed boundary to get a solid.
You have the full model & I see an array of the surface.  I Explode the array to get individual petal surfaces and I select one of the surfaces.  I then Move that surface a distance (50 units) above the part in the Z direction.  I close the bottom of the petal with a Patch Surface using the edges of the existing petal.  I then Union the patch surface and the existing loft surface (there is a notice that union is not recommended but I accept anyway).
Now I use Convert to Solid on the Mesh ribbon and the union-ed surface becomes a solid.
Now I can Move the solid back onto the intended assembly and array it once again after deleting the remaining surface petals.  You will now be able to Union the solids.
Cheers,
Blaine
Blaine Young
Senior Engineering Technician, US Army
Message 11 of 39
I think I managed to achieve that with patching and Union surfaces. I transfered shape into new file. How do I know that whole shape is truly solid?
Message 12 of 39
parkr4st
select the array; Xplode once and select any part; properties will state 3D solid for all the parts.
remember way back in this thread https://forums.autodesk.com/t5/autocad-forum/extrude-object-removed-from-selection-set/m-p/7364591#M...
I stated
there is/are problem(s) in the original line work someplace.
Zoom in on the end of a petal and you can see the petal does no align with the part below it.  very minor stuff and may be acceptable.
after the surface patch it may pay to extrude that surface down 5 units and replace the bases with that solid if you need exact alignment.
good luck with the project.  you have done well working through the project.
dave
Message 13 of 39
Dmn it, im gonna have to start over... im so lost here...
Message 14 of 39
dieters
That's how we learn.
But first, as Alfred suggested, get very comfortable with the User Coordinate System. The UCS is essential to establish construction planes (UCS + 3 points), orthogonal directions, and axes of revolution (UCS ZA). Use the attached DWG to practice on: draw a circle on every plane. Make the UCS Z axis align with the ridge and use ROTATE to make the swing rotate.
Next create profiles in 3D by creating 2D geometry, using BOUNDARY to create a closed polylines (or regions) from objects that enclose an area. With the ZA option of the UCS command, establish axes of rotation and rotate the closed polylines into place.
Then, use EXTRUDE, REVOLVE, and SWEEP to generate 3D solids from the closed polylines.
Finally, combine the results with Boolean operations such as UNION, SUBTRACT, and INTERSECT.
Tip: Turn off DELOBJ to retain your original profiles and put them on a reference layer. You'll likely need them later for sanity checks and for recreating some of your 3D solids.
Dieter
Dieter Schlaepfer
Principal Learning Experience Designer
Autodesk, Inc.
San Rafael, California
Message 15 of 39
How does one convert extruded object to solid?
Message 16 of 39
dieters
The extruded object in your DWG is already a 3D solid. You can verify objects in your drawing with the LIST or PROPERTIES commands. You might want to use the Conceptual or X-ray visual style to view your model.
What kind of dome? Hemispherical, parabolic, faceted, trimmed?
Dieter
Dieter Schlaepfer
Autodesk, Inc.
Message 17 of 39
There, I have prepared for another try to create this flower (in .pdf) I only extruded polygon and circle, did not _Union them. Dome (this part also should be solid) and petal surface (Not solid) and the polygon itself I have aligned with UCS - Thanks for Advice. Now Since I have everything ready, I need this flower to be just like in .pdf, & solid shape. What are technical details to create such object, so I am sure that it is in solid form? 🙂
Message 18 of 39
john.vellek
Hi @Anonymous,
I took a look at the sample file you sent me.
I noticed you had the base drawn correctly with a height of 5. (but with only 9 sides and not 10)
Then I noticed that the petal also has a base height of 3 before it arced.
The inner dome (with a height of 7) sits upon a base with a height of 3.
  • So, on your base, I create a cylinder (at the center) with the height of 3 to act as the base of the dome.
  • Next, I took the outline of the petal (making sure that the inside radius where it meets the dome had the correct diameter) and PressPulled it to a height of 3.
  • Next, I took the center line of the petal and lofted it with both side of the petal outline.
  • Next, I drew a horizontal line from the center of the dome base to the edge of the dome base (length of 12.5)
  • I drew the vertical curve from this endpoint back to the centerpoint (top) of the dome. I used JOIN to connect the arc and the horizontal line.
  • Then I used Revolve on this joined linework and revolved about the vertical center axis of the dome.
  • Lastly, I uses ARRAY to get a total of 9 petals rotated around the center of the dome.
Now I could UNION all the pieces to make a single solid.
I have attached my version of this process with copies of each phase in its construction.  I hope that I interpreted the sample correctly and that you can follow all of these steps to create your own (hopefully better) version of this design.
John Vellek
Message 19 of 39
Does polar arraying of 1 segment creates other 9 in solid form?
Message 20 of 39
parkr4st
John, nice job. Kudos to youSmiley Happy
 Aleksandras   pay attention to John's added cross sections to form the petal.  a cross section at each node along the sides, that fills out those minor voids of your petal.
but the solid petal part, go back to blyoung post using SURFPATCH and form a "bottom" to the petal;
as stated in that poat
Aleksandras,  give out the kudos to all the helpers in your post,  all are well deserved.
hope you can draft this and other objects like it now.
Kudos to all the help here!
dave
