Can you put Model/Layout tabs above the Buttons in AutoCAD 2015?
This is kind of a weird challenge.  I just got updated to AutoCAD 2015 finally.  I noticed that the Model/Layout tabs and the buttons below the drawing are on the same line and crowding tabs out on drawings with excessive Layout Tabs.  Is there a way I can get them to display one above the other so that I can see more of my tabs?  Image attached in case it is too small in the browser.  Thanks for your timeLayout Tabs Crowded By Buttons.png
Alfred.NESWADBA
You are on the right way 😉
Right-click onto one of the layout tab's and select "Dock above Status Bar"
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
That was it exactly, thank you.  I like how easy that is to switch back and forth.
