AUTOCAD 2015 - RCP FILE
IS THERE A WAY TO LOCK THE POSITION OF THE RCP POINT CLOUD FILE SO IT CAN NOT MOVE AND STILL BE ABLE TO CROP THE SCAN DATA VIEW?
filipefrancisco
Hi
Try to do this
http://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/AutoCA...
Hope that helps you
Cheers
Filipe Francisco
Comunidade Autodesk - Português - Colaborador
Autodesk Certified Instructor | AutoCAD Certified | Revit Architecture Certified | Autodesk Expert Elite
YOUTUBE | LINKEDIN
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou.
If the answer solved your problem, click Accept as Solution. This helps other users to quickly find an answer. And hit Like if you do.
Autodesk Community
The problem is that when the point cloud layer is locked - you can not crop or modify the point cloud to be able to work with the data.
when you unlock the point cloud - then you can crop and work with the data - but it is also free to be moved around (bad if it is the background for your design).
