Convert a table drawn with lines and text to an AutoCAD native table.
Hello — I have a dwg file with a bunch of tables, however, it appears the tables were drawn with lines and text... not built using the table tool. I need to get these converted to an AutoCAD native table or excel file. Any suggestions? I have looked into "TableBuilder", however, it is just for windows users. Please and thank you!!
kcobabe
There are several lisp routines written that are out there that can do just this.  Do a search for "text to mtext lisp" several will come up.
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
Is there a way to do this on a Mac? I did find a couple ways using Express Tools, however, doesn't appear it's available on the Mac platform.
pendean
Community Legend
Community Legend
As noted in the reply above your post, there are many text-2-MTEXT lisp routines free that you can find with an Internet search. Help yourself.
Hello — Thank you for the replies. I am a graphic designer and very (VERY)  new to AutoCAD. From my research and google searches, I have found that when searching for the lisp routinues, that I need Express Tools to use them. I do not have express tools, and it appears it only works on windows platforms? Thanks for your help.
kcobabe
Nope, you do not need express tools.  Use the "APPLOAD" command and browse for the .lsp file.  If it's something you know you will use a lot of, add it to your Startup Suite:
undefined
R10 - 2020 ACAD
2014 - 2020 Revit
Infraworks
2018-2020 Inventor
2020 Navisworks
Type a product name
