Can you merge polylines and hatches with an OLE object?
I pasted a table from Excel into AutoCAD, then I drew and hatched rectangles within it to create a color-coded planting  concept. How can I combine all of these to create a single object?
Justine
sthompson1021
If you are just using it in that one drawing, you could just use the GROUP command to keep them together. If you want something more permanent, you could make it into a block.
I successfully turned it into a block; thank you!
Justine
