AutoCAD Forum
Can't select on the line gap
8 REPLIES 8
Message 1 of 9
716 Views, 8 Replies
 Hey,
I'm using Autocad 2016 and LTGAPSELECTION is an unknown command.
As the tittle says, when i try to select on the gap of the line, it just go through, without select the line needed. Any sugestion?
 Hey,
8 REPLIES 8
Message 2 of 9
TheCADnoob
TheCADnoob
I believe that was not a part of the program until release of 2017
https://jtbworld.com/autocad-2017
CADnoob
CADnoob
Message 3 of 9
ReneBogersREBO
ReneBogersREBO
LTGAPSELECTION is available from version 2017!
Try turning off hardware acceleration trough GRAPHICSCONFIG command
Message 4 of 9
in reply to: TheCADnoob
You mean that there is no way I can do this on this version? Click the gap to select the line?
Message 5 of 9
in reply to: ReneBogersREBO
Already tried it, doesn't work
Message 6 of 9
ReneBogersREBO
ReneBogersREBO
If that doesn't work, than I am afraid it's not possible... only thing I can think of is to bigger the selection box, but I can imagine thats not what you wanna do!
Form version 2017 it is possible if I am right.
(I don't have AutoCAD here anymore, so can't check it out, only Revit on my machine :s)
A crossing maybe could also work I guess.
Crossing is, when your crosshairs are dotted instead of continuous (dotted or continuous depens on the movement bottomleft to upper right, or upper right to bottom left).
Message 7 of 9
Patchy
Patchy
Just like newer vehicles come with airbag, old one have none and you buy new vehicles if you want airbag.
Message 8 of 9
TheCADnoob
TheCADnoob
Not unless it was released with a patch later in the year, but i dont think they did that with this command. You can make sure your version is up to date and see if it in there, but i dont remember them pre-releasing that command.
CADnoob
CADnoob
Message 9 of 9
RobDraw
RobDraw
Correct.
Rob
Correct.
Rob
AutoCAD Inside the Factory
